3rd function kit
   / 3rd function kit #2
Looks like that's a diverter and not a true third function if that matters to you.
   / 3rd function kit #3
Seems a little pricey. You don't need a 24GPM valve. Here is a better priced kit if that's what you want.
   / 3rd function kit
Ok thanks for the info. I guess a diverter has 6 ports and a true third function has 4 ports. Thx for the info on a better price!
   / 3rd function kit #5
MtnView, can (should) you run a hydraulic motor with the diverter valve kit you linked? If not, any suggestions?
   / 3rd function kit #7
You can use a diverter to get the additional set of outlets, but the main controlling valve should really be a motor spool valve (a control valve specifically built to operate a hydraulic motor) which most people don't have, so you need to always keep in mind that you should slowly feather the valve closed when stopping the hydraulic motor.
   / 3rd function kit #8
?? So a set of outlets, from a diverter off the curl/dump function of a fel won't work? I don't see how you can scroll between curl/dump and motor on, when the motor is on? What am I missing?
   / 3rd function kit #9
You can't. The proper way to operate a hydraulic motor is to use a motor spool valve. The problem with a motor spool valve is that you can not use them for cylinders. So with you using your loader valve and a diverter to run I assume a hyd PHD, you need to keep in mind that you need to feather down the motor before you let off the diverter control switch.
Lots of people do this without any problems, but that does not make it right.
2017 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2017 GENIE...
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
2025 LandHonor SD-22-72W 65in No Till Seed Drill for Tractor and Skid Steer Attachment (A49462)
2025 LandHonor...
1275 (A50490)
1275 (A50490)
