4:1 Bucket for Kubota LA402 FEL - feasible?
   / 4:1 Bucket for Kubota LA402 FEL - feasible? #1
penokee
Platinum Member
Little Girl's Point (Lake Superior), MI
Ferguson TO-20 (sold to son-in-law), AC - H3 Crawler, L3130HST, (AC-WD w/Attachments - SOLD), 1984 Honda Big Red, Honda Foreman 4x4 w/plow
Planning to purchase a Kubota B7800HSD and wondering if a 4:1 bucket is available for this size CUT and if a B7800 tractor can handle it. Appreciate all comments pro and con.
penokee /forums/images/graemlins/smile.gif
   / 4:1 Bucket for Kubota LA402 FEL - feasible? #2
Penokee,
Don't know what the lift capacity of the 402 is, but 4n1 buckets typically weigh quite a bit more. I know that mine weighs about 600-700 pounds. I use it on a NH TC40D. I love the 4n1, but it certainly reduces the lift capacity.
Larry
   / 4:1 Bucket for Kubota LA402 FEL - feasible? #3
</font><font color="blue" class="small">( Planning to purchase a Kubota B7800HSD and wondering if a 4:1 bucket is available for this size CUT and if a B7800 tractor can handle it. Appreciate all comments pro and con. )</font>
You might want to read this thread. There are some (resolvable) issues with the regenerative circuit on some of the Kubotas.
FEL grapple 'close' is weak...help please
   / 4:1 Bucket for Kubota LA402 FEL - feasible? #4
Yes, you can get a 60" 4-in-1 for your Kubota LA402. TBN advertiser, ATI Corporation, builds one. But, its a lot of bucket for that B7800 tractor. The 60" 4-in-1 bucket weighs 350 lbs. which is close to twice the original equipment bucket's weight.
4-in-1 buckets are great for working with brush. But on my 1520 Ford, which weighs hundreds of pounds more than a B7800, it is a lot of bucket hanging out there.
I think that it would be better to step up in tractor size to get a tractor with more total mass if you plan on using loader attachments. Don't deny yourself the pleasure & versatility of a 4-in-1 bucket over something as insignificant as a smaller tractor. /forums/images/graemlins/smirk.gif
   / 4:1 Bucket for Kubota LA402 FEL - feasible? #5
Bucket, Grader, Grapple, ?????? What is the 4th function of a 4:1 bucket?
   / 4:1 Bucket for Kubota LA402 FEL - feasible? #6
</font><font color="blue" class="small">( Bucket, Grader, Grapple, ?????? What is the 4th function of a 4:1 bucket? )</font>
It also grades (cuts) going backwards. Open the bucket, dump the bucket and you have a cutting edge facing to the rear. Makes removing a thin layer easier since you can see what you are doing.
   / 4:1 Bucket for Kubota LA402 FEL - feasible? #7
Wouldn't this be like a box blade?
   / 4:1 Bucket for Kubota LA402 FEL - feasible? #8
</font><font color="blue" class="small">( Wouldn't this be like a box blade? )</font>
Yes, except that a box blade usually has teeth to break the ground.
Much good information, thanks all. Clearer to me now, that if I want a 4:1 bucket a larger tractor may be needed. Have to decide if I have enough work for the 4:1 or do I stay with the B7800 and the standard bucket. Something for me to mentaly wrestle with while factoring in the all important buget issue. Have learned a lot from this Board in just a short time /forums/images/graemlins/smile.gif
penokee
   / 4:1 Bucket for Kubota LA402 FEL - feasible? #10
Penokee.
Hi, Waming up a bit this week. May have some summer yet.
I have a 4in1 on my Kubota and love the functions it allows me. I have done many things with it- light dozing, brush hauling, stump moving, along with the regular bucket things.
It has about 20% less volume than the regular bucket and mine weighs about 150lbs more but would not trade it for any regular bucket.
I still hold to the statement my dealer made to me- The L3130 is only a grand more than the B7800 and is a full sized CUT. You will get what you want , this is for sure but I traded and lost some money to finally get what I wanted in the first place. Many on TBN have traded up or sold and gone bigger. Except for RAT but he was at the top of the cuts and had other needs.
Hard choices. Best of luck on your decission.
377789 (A51573)
377789 (A51573)
2011 Ford F-350 Knapheide Stakebed Truck (A52377)
2011 Ford F-350...
2015 Kaeser M114 100psi Towable Air Compressor (A51691)
2015 Kaeser M114...
2021 John Deere 8R 250 (A50123)
2021 John Deere 8R...
John Deere 848G Grapple Skidder (A52384)
John Deere 848G...
2007 Allmand Night-Lite Pro Towable Light Tower (A51691)
2007 Allmand...
