4 in 1 bucket vs grapple, which would you buy and why?
   / 4 in 1 bucket vs grapple, which would you buy and why? #21
CPM of Qld, they were offering the BH92 on both the L4400 and MX5100 until january but they are not now permitted under OH & S reasons of which they wont explain.
They are going to bring in the L4600 later this year that will have a BH...or you can try looking at the L3800 with a BH77. Depends what you need to do.
Im about to order the MX5100 with a subframe if i can get it that way in case they change their minds later if the price is right but without the BH now as i think the L3800 is going to be too small for me. Grapples are great but 5 times too expensive in Australia than USA.
   / 4 in 1 bucket vs grapple, which would you buy and why? #22
CPM When i asked for a price in Melbourne on the B26 TLB the price was about $50,000 saying it was more heavy duty than the L4400 and other models.
But i would ring up another dealer for another opinion on frame strength of the MX angainst the L ...... sounds like mis-informed advice from your dealer.
   / 4 in 1 bucket vs grapple, which would you buy and why? #24
Give Norn Buckets in Brisbane a ring,they should be able to sort the buckets you want without having the dealers margin on top,and quick hitch as well. :thumbsup:
   / 4 in 1 bucket vs grapple, which would you buy and why? #26
I have both a 4n1 and a grapple. I agree the 4n1 is like a Swiss Army Knife or Leatherman. Does a lot of tasks but none as well as a dedicated tool. On the other hand, a light duty grapple is a dedicated tool and does work extremely effectively.
If I was a contractor trailering my tractor to jobs I would probably want a 4n1 but if I am at home and can switch implements conveniently then in my experience the grapple is mounted far more often than the 4n1.
The main weakness if the 4n1 is that it picks up "grapple" loads from the bottom. One big branch is about all it can grasp as anything below that will not be compressed due to the pinching nature of load securing. A grapple has fixed bottom tunes do gravity holds the load in place. I can load literally 5-10 times as much brush into my grapple as into the 4n1.
Also, a perfectly good grapple can be had for $500-1000 while 4n1 costs start at close to $2000. Finally, as others have noted, it isn't hard to damage a 4n1 and repair is expensive. Grapples are very hard to damage and repair is done with heat and hammer.
   / 4 in 1 bucket vs grapple, which would you buy and why? #27
As I was learning to operate my 4-in-1, that too was my initial impression. I was trying to pick up a pile like a kid grabs a stuffed animal out of a mahine; from the 9 o'clock and 3 o'clock directions. But as time went on, I realized that was simple inexperience speaking. To increase the amount of brush a 4-in-1 can pick up is just a matter of technique. I first use the closed bucket (full curl at ground level) to push/roll the pile forward so it becomes more compressed. If further compression is desired, I lift the loader move forward, rotate the bucket to full dump, lower bucket back to ground level, and pull the pile back. Then to pick it up, I
1. open the jaws all the way on the near side of the pile,
2. set the curl so the bottom jaw is vertical AND at ground level (think 12 o'clock and 6 o'clock)
3. then close the jaw as I'm driving forward.
Closing the jaws around the pile from 12 o'clock to 6 o'clock while pushing forward - results in a MUCH bigger bite.
//greg//
   / 4 in 1 bucket vs grapple, which would you buy and why? #28
greg_g said:
As I was learning to operate my 4-in-1, that too was my initial impression. But as time went on, I realized that was just inexperience speaking. To increase the amount of brush a 4-in-1 can pick up is just a matter of technique. I first use the bucket to push/roll the pile forward so it becomes more compressed. Then I open the jaws, set the curl so the bottom jaw is vertical relative to ground, then close the jaw as I'm driving forward. Takes a MUCH bigger bite that way.
//greg//
I am sure that does work but would still gobble less than a grapple especially with thick branches or logs as the pinch closure simply makes it impossible to hold anything below whatever object is jammed in the top.
I use my 4n1 but not when my primary task is brush. I like it mounted with my backhoe so I can fill in the hole after stump removal and carry the stump away.
   / 4 in 1 bucket vs grapple, which would you buy and why? #29
So does this mean we can add grapple vs 4 in 1 bucket to the list that includes R4 vs R1, HST vs gear, etc. :laughing: It's nice to read everyone's opinion on the subject.
   / 4 in 1 bucket vs grapple, which would you buy and why? #30
CPM have you seen any BOLT ON GRAPPLES for sale in Qld or the price? Should be much cheaper than the pricey Grapple Bucket prices.
Bolt on grapples for buckets are a very reasonable and very economical alternative to a real grapple. While building a true grapple from scratch would be a fairly major fabrication job, a simple bolt on grapple could be put together by an amateur welder without much difficulty. The upper grapple arm does not do most of the work as the load is supported by the bucket and the grapple arm just keeps it from falling out. Therefore the upper arm does not need to be heavy duty and while a nice computer/plasma cut curved tine looks great, you could fabricate a perfectly functional upper arm with just pipe and angle iron (not sure what you Aussie's call those things). The hydraulic cylinders can obviously be accessed from multiple sources too. The key issue would be getting the geometry right but working that out with plywood or even cardboard should be pretty easy. If you look on the US ebay site you'll see upper arm grapple kits for buckets being sold for roughly $300. Not sure about shipping etc but that should give you a rough idea (multiplied by the down under mark up!).
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
Grasshopper 721 Zero Turn Mower (A59814)
Grasshopper 721...
208315 (A58376)
208315 (A58376)
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- DEMO UNIT (A56438)
Greenworks...
