4 in1 loader is great
   / 4 in1 loader is great #1
Hillbilly
Platinum Member
Finally bought a JD loader for my JD 4400,while I was at it I decided to go with the 4 in 1 loader.I had people tell me the loader was the most handy thing on there tractor,well I would have to agree now,but I would also have to say the 4 in 1 bucket makes my loader even that much more useful,amazing the uses I have found
with a loader,a back saver and time saver.
I have used the loader to lift numerous T - posts out of the ground,I have grappled several logs 12" to 15" in diameter and 12' to 15' long and stacked them.Yesterday I removed part of an old electric pole out of the ground.The pole had been set 18 years ago and a couple of years ago it was cut of at ground level.I took the loader and scraped a little bit of dirt from around the pole and opened the 4 in 1 an wiggled the post around and lifted it up out of the ground, about 3' long and then went back an pulled the old ground rod up as well.Tree tops across a road in the woods,I opened the loader up and pulled the top out of the road and carried where I wanted to drop it and opened the loader and let it fall.Great investment for me.
   / 4 in1 loader is great #2
Hillbilly, that’s a great addition to your tractor, congratulations on the new loader. How are the controls set up for your 4 in 1? Sounds like some have an extra lever and some a button to activate the jaws.
I think it was MarkC that used his to trim low branches from trees on his trails. Always thought that sounded like an unexpected use.
MarkV
   / 4 in1 loader is great #3
HIllbilly could i ask how mutch it was i had a bear of a time removing grounding rods had too dig most of it out also dropped abunch of trees and need help cleanig them up is the 4 way hard too learn to operate? and what size bucket is it
thanks edt
   / 4 in1 loader is great #4
Hillbilly:
Congratulations on the addition. I agree with you on the utility of the 4-in-1 bucket. I just bought a Ford 1520 that had a 4-in-1 bucket on it. I had a lot of railroad ties that the previous owner had used for landscaping, that I had to move to do work on my driveway and some clearing for pasture. The 4-in-1 bucket just allowed me to pick them up and take them wherever I wanted them. I could even stack them neatly. A real back saver. I have also used it to clear downed trees from trails and the dozer capability with the bucket wide open has been usefull for moving dirt and manure piles. I don't think I will have another tractor without the 4-in-1.
Men,
The 4 in 1 bucket cost around $5500 installed of course.Sounds a little high...but I did not have any SCV's at all connections etc..this all had to be installed.It was a little steep.My dealer is on the high side,but I always get good service and all the good dealers are 30 to 50 miles away.
The bucket is 5' wide(430 loader).
It is easy to operate...2 levers....one to raise/lower and curl the bucket...and another lever located on top the right fender to open and close the bucket....it is easy a heck to use and operate....they talk about these JD loaders being so easy to disconnect and reconnect....heck I could not tell you one way or another...I have not had a reason to take it off and I cannot see me ever wanting to take it off/w3tcompact/icons/laugh.gifalthough I am sure sometime it will need to come off.
2084 (A49339)
2084 (A49339)
New Skid Steer Root Rake 34'' (A48289)
New Skid Steer...
2114 (A46502)
2114 (A46502)
3013 (A49339)
3013 (A49339)
2009 Peterbilt 384 Day Cab T/A Truck Tactor (A46683)
2009 Peterbilt 384...
S/A Pull Behind Aerator (A46683)
S/A Pull Behind...
