4 ply to 6 ply
   / 4 ply to 6 ply #1
Bootlegger750
Bronze Member
Crossville, TN
Mahindra 1640 Shuttle shift
My Mahindra max 28 has 4 ply stock tires on the front. They are Starting to dry rot. Probably going to put a 6 ply on it. Same size tires, so going to 6 ply wont matter will it?
   / 4 ply to 6 ply #2
Not only is it a good idea it shouldn't make a difference. What will make a difference is often the same tire size from different manufacturers will vary a bit.....but not enough to make a difference.
   / 4 ply to 6 ply
Ok, thank you. It has Carlise on it now, will either go with Carlise 6 ply, Camso 6 ply, or the Kenda 6 ply. All are about the same price.
   / 4 ply to 6 ply
From what I've found...all inflated size were 22.5 to 22.6. I doubt that little difference would bother the 4wd
   / 4 ply to 6 ply #8
Measure the circumference of the tire and if it is identical....tire pressure or lack thereof equal, consideration for loss of tread on old vs new, you are improving your situation going to 6 ply. If you had a 2wd it would be a no brainer period.
On sidewall strength, I went from a 6 ply 12x16.5 Industrial (came on tractor new) to a 4 ply 33x12.5xx16.5 (same circumference) thinking I'd get a softer sidewall.....well sorta, not what I expected. I did get a larger balloon which helped to absorb some shock going over bumps but it was still stiff.
Claas 340 Round Baler (A50774)
Claas 340 Round...
New Holland 273 Square Baler (A50774)
New Holland 273...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2021 New Holland Workmaster 25S Compact Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 New Holland...
NEW Fork Extensions (A53002)
NEW Fork...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
