4" Stump Removal
   / 4" Stump Removal #1
RMEADOWS
Bronze Member
Lakeland, Fl
MF 1428
4\" Stump Removal
I have cut about 50 trees, all 3-5", most are in the 4" range. I've cut the all about 6-8" above gound so I can see them and attact them.
I have a L245, no FEL, but do have a box blade. Any suggustions on the proper way of removing the stumps with the equipment I have. BTW, I'm cheap and have time to do this. Really don't want to spend the money to rent a bobcat.
Thanks,
Roger
   / 4" Stump Removal #2
Re: 4\" Stump Removal
A shovel and axe to cut bigger roots then try to pull out w/ tractor.
If they were standing u might have been able to push over w/ tractor and box blade.
Since u only have 2wd u will be limited on pulling power.
U might try putting one or two shanks down and using box blade to tear thru roots.
A cheap single shank ripper might be helpful.
   / 4" Stump Removal #3
I spent over 20 years with a L245, wonderful little machine. I do believe that you are over your head trying to remove that size stump with that machine. If you find a way, I'd like to know.
Good luck
Gil
   / 4" Stump Removal #4
Find a 3pt single bottom land plow. bcs
   / 4" Stump Removal #5
If you can dig underneath one to the roots, you might be able to double wrap a chain around the whole stump and the root and pull it out.
Greg
   / 4" Stump Removal #6
I've removed my share of stumps of the 4 inch size. It can be done but it requires a lot of labor. A small tractor is not a much help. You will end up digging a lot; and choping roots. /forums/images/graemlins/confused.gif
If it were me, I would hire someone with a backhoe or a stump grinder. I am having 6 stumps ground this week. The guy is charging $40 ea for the 24 inchers and $20 ea for the 6-8 inchers.
John
   / 4" Stump Removal #7
I think a guy with a bulldozer would take them all out pretty fast. That is what I used and the guy only charged my $165.00. He remove over 100 trees. Now the reason he was pretty cheap was because he already had his bulldozer on my property doing other things.
murph
   / 4" Stump Removal #8
Do your 245 a favor and rent a dozer for a day. You will have them out in no time. That or a backhoe, would be easier to make the stumps disappear.
   / 4" Stump Removal #9
Sorry, this won't help you now, but next time leave about 3 or 4 feet of stump. Then chain to the top and pull or use your box for pushing the top, repeatedly from all sides. This will expose the roots which can then be cut until the stump comes out. It will still take a while but the addditional leverage gained from the longer stump really helps.
   / 4" Stump Removal #10
Buzst,
He has fifty of them trees. That would take a long time to remove everyone of them. Get a bulldozer and enjoy life.
murph
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
Taylor Dunn Big Foot Electric Cart (A50324)
Taylor Dunn Big...
John Deere 603 3 pt Mower (A50514)
John Deere 603 3...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2020 FREIGHTLINER...
Backhoe Attachment (A50322)
Backhoe Attachment...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
