4000 ford clutch will not release
/ 4000 ford clutch will not release #1
david mcgill
ford 4000
clutch will not release we do not know if it has the right clutch it has single clutch some tells me it must have double clutch:) it is three cyl diesel with a ehght speed when i bolt on the pressure plate as i tighten it it pulls the pressure plate arms in toward the clutch disk so there are no room for depressing and releasing the clutch it acts likes the pressure plate needs shims but ford tells me no
:confused2:
:licking::p;):(
please help
can any one help me
/ 4000 ford clutch will not release #7
did you put the clutch disc in the right way.Sounds like its facing the wrong way leaving no room to bolt up
it will only fit one way you can not put this one in wrong
/ 4000 ford clutch will not release #10
Hi Dave. I'm not famiiar, with your tractor. On some tractors, with a single clutch disk, the fly wheel is steped. The pressure plate bolts to the outer ring, and the clutch disk sits in the recess. If this is what you have, the distance from the surface of the recess to the face has to be machined to a specified depth.
Dave
/ 4000 ford clutch will not release #11
David. Welcome to TBN.
I can't help directly, but there is a New Holland section on here and you may want to move your question over there.
Also here is another website to post to.
Antique Tractors - Yesterday's Tractors : Antique Tractor Headquarters.
When posting people will want to know a few things.
What year is the tractor. I'm assuming since it's a 3 cyl with and 8 speed that makes if built after 1965.
Good luck and please let us know how it turns out.
Wedge
2019 Chevrolet Silverado 1500 RST 4x4 Crew Cab Pickup Truck (A59230)
2019 Chevrolet...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
