4010 steering cylinder stripped!
   / 4010 steering cylinder stripped! #11
A metric thread file might clean up the male thread enough to screw it all the way in.
I failed to mention that I did also used the die on the male end. It cleaned up well enough to put it back together. So I did that, And slowly pulled it into the storage area so it wasn't stuck in the middle of his property. My gut says I could use the loctite stuff on it right now, and be fine, however having those extra 1/2" of threads makes me feel better if I'm in high gear doing 15mph down a back rd.
Some of the other issues we've had with it, is the steering issue, Where the steering wheel turns but the wheels don't. I almost took out a mailbox and swerved into oncoming traffic on that little issue. That was warranty work thank goodness. Also, the brakes were seized upon delivery.... Couldn't figure out why it was so sluggish until we were using the loader on a parking lot snow removal job, And I was skidding all over the lot with one tire.. The 4wd shifter locked up as well. I could go on, but most of the others were issues we had with the dealer we bought it from.
It's still a tough machine. Mostly human error caused all the issues.
   / 4010 steering cylinder stripped! #13
Do not loctite or weld on it ! That thread is still good to hold a lifetime !
   / 4010 steering cylinder stripped! #14
BOTH sides should be threaded all the way in and tightened to the cyl rod. Those threads moved back and forth during steering and wore out. Just a good clean up and threading completely together may provide the necessary strength.
2013 Ford Focus Sedan (A50324)
2013 Ford Focus...
1999 Chevrolet 1500 (A50121)
1999 Chevrolet...
2021 Hyundai Elantra SEL Sedan (A50324)
2021 Hyundai...
Ford F800 (A50121)
Ford F800 (A50121)
John Deere 4020 (A50120)
John Deere 4020...
