davrow
Veteran Member
Sounds like two speeds... on and off. :laughing:
Don't you sell these tractors? If so, don't you have a manual for the 4035? Where does it mention two speeds on a joystick, what page?should explain it in the manual
I've often found it to have more travel before performing functions than desired as well, although it doesn't seem to affect my precision any, only my speed when being precise because so much time is taken feathering through the free travel of the joystick. I've found that higher RPMs help. The audible cues stand out more (the higher pressures make more noise as the valve begins to divert the flow to perform a function), and the range of feathering is smoother.
There is an adjuster on the cables from the control, where it connects to the valve. The manual doesn't state any adjustment procedures, but I'm sure you would just take all the slack out of the cables as is possible so they operate the spools with as little play as possible.
