acs55812
I have a rear blade and noticed a "new" problem with the three point not lifting a couple weeks ago when cleaning up the driveway. It happened a couple times and I didn't think too much about it---it lifted when I backed up (away) from the pile of snow I had accumulated going forward.
Today it did it and it seemed worse, I was thinking I was going to have to drag it back to the shop and back in with it down---finally it did lift.
When it lifts it seems to lift at full speed and height, when its not lifting the front blower seems to lift fine.
Asking for possible cause may be premature---I have not checked fluid level,,,but have no fluid spots under tractor, the fluid was change a couple years ago with less than 50 hours usage since that time.
In past years I have had 900 pound of weight on the rear for traction, with no problem lifting---was it possible that was too much and wrecked a pump? Does the from and rear use the same pump?
Thoughts?
Thoughts?
