4110 has a pto whine
   / 4110 has a pto whine #1
coffeeman
Platinum Member
Hi all
Can anyone guess if this sounds ok.
When cruising along with rotary cutter running I hear a whine in pto. About 1/2 speed not much load hit a bump and err..err..err...err...err. Sounds like an old manual trans pickup as it lobs over a hill and sort of coasting on level. When I shut pto off it quits, so I guess it's pto. I can't remember if this is normal as of last year. I can't find tractor manual to check if I missed some oil check point. I'll have to look for it as they are expensive.
Cheers...Coffeeman
Hi all
Cheers...Coffeeman
   / 4110 has a pto whine #3
Check your Hyd. fluid level first before you use it again.
Have you changed it since it was new?
Ernie
   / 4110 has a pto whine #4
Ernie
   / 4110 has a pto whine #5
Coffeeman,
I second the hydraulic fluid level check (rear end).
My 3510 (same tractor, smaller motor) just started the same thing. When PTO all the way up, some whine, especially when unlevel.
I checked the fluid, it is low. Not out, and whine goes away when lowered slightly and top tilt cylinder closed.
It just happened and I checked the fluid (while running) and parked it. I'll put fluid in it as soon as I get the chance.
Sort of like the whine power steering makes when low....
-DiskDoctr
   / 4110 has a pto whine #6
Coffeeman,
-DiskDoctr
I changed all the oils at 60 hours. (I'm pretty sure I got all of them.) Where do you check the fluid? There is a dipstick on the rear left axel. Darn, I gotta find that owners manual.
Coffeeman
Coffeeman
Yes
It's like a power steering whine.
Cheers....Coffeeman
Yes
Cheers....Coffeeman
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2007 JLG SkyTrak 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
JCT SKID STEER QUICK ATTACH AUGER SET (A51243)
JCT SKID STEER...
1998 JOHN DEERE 310E BACKHOE (A51242)
1998 JOHN DEERE...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2 pt IH Sickle Bar Mower (A50515)
2 pt IH Sickle Bar...
