4110 jd will it handle a grapple
   / 4110 jd will it handle a grapple
thanks folks for the advise:
I am just checking into a grapple, I do not have one picked out yet and not sure where to start. I just know the wood i work with most often is large 30 in down to 6 inch, now I just cut up the large stuff to a lenght that fits in my bucket. But smaller logs I would love to pick up in 6 foot lenghts etc. So I guess Iam in need a basic help. My 4110 does not have loaded tries, I just use a rear blade for wait.
I would love to know all that you all know.
thanks
roger
thanks
roger
   / 4110 jd will it handle a grapple #13
Jason,
Can you estimate what your costs were to get the grapple up and going? It looks great.
chop
   / 4110 jd will it handle a grapple #14
Jason,
chop
   / 4110 jd will it handle a grapple #15
Chop-
I had $310 in the diverter valve (Fasse-thru JD dealer)
I had about $75 in hoses/fittings (brother-in-law make hoses)
I had $420 in grapple (bought from A Tatro thru Ebay)
I had about $100 in steel to make the grapple mount.
Total- $905 and worth it!
I also made a FEL snowplow, so the diverter works the angle on that.
I use the grapple a lot, I am clearing some land. I dig out trees with the hoe then turn around, pick them up and either cut them up or haul to burn pile. Wouldn't do without ii.
/forums/images/graemlins/smile.gif
Jason
   / 4110 jd will it handle a grapple #16
Chop-
Jason
JasonL
you post makes me want to get out and hit the woods.
Do you have any pics of your set up. I have no skills in making this myself, did you have plans or just work it up in your head.
What amount of wieght do you think you can lift with your grapple.
thanks
roger
JasonL
thanks
roger
   / 4110 jd will it handle a grapple #19
Roger-
The only pictures I currently have are the ones I posted in the thread I linked to earlier in this thread.
I don't often stop to take pictures in action as then I have to get off the tractor! /forums/images/graemlins/smile.gif
Basically some box tubing and plate material is all you need to mount the grapple as I did.
As to what it will lift? Probably more than I should. I forget what the grapple and mount weigh- maybe 125 lbs?- so that much less than without it I guess.
I picked up a cherry tree stump (14" dia) with the entire ball of roots (including dirt) and moved it yesterday!
Awesome attachment! I've never removed it since I installed it, but it just requires removing 3 pins and unhooking 2 hoses.
If you're playing in a wooded area you won't believe how helpful a grapple is.
BTW- I had no plans, just pictures/ideas gleaned from others at TBN!
/forums/images/graemlins/smile.gifJason
   / 4110 jd will it handle a grapple #20
Roger-
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
24' PIN ON EXCAVATOR BUCKET (A52707)
24' PIN ON...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
