4110 Oli filter removal
   / 4110 Oli filter removal #11
Glad it came off for you.
The oil filter on my Mahindra 5525 is almost completely obstructed by one of the FEL support members.
I can get to the bottom of the filter and to the top 1" of the filter. So I use this $9 Fram filter pliers from Walmart to grab around the accessible top of the filter.
Works fine.
This is what seems to work for the 4530 too. The designers of these tractors didn't seem to take filter access into their design criteria.
   / 4110 Oli filter removal #12
I have a 5525 too. My problem today is the assembly above the filter with the two hoses is moving but the filter is frozen to it. The wrench is starting to dent the filter but hasn't punctured it yet. I guess I will go ahead and put fresh oil back in the tractor and warm it up as BobG suggested... but then I have to go get more fresh oil to start clean again. Not the delay in getting done I was expecting.
   / 4110 Oli filter removal #13
Just change the filter, since you are putting new oil in, why waste it.
Good luck on getting that filter off.
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
2013 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2013 MACK GU813...
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
1275 (A50490)
1275 (A50490)
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A49461)
2012 Ford F-550...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
