Jdmano
Does it blow black smoke like its getting to much fuel or does the crankcase just fill completely with diesel?
Tractor has 750 hrs,no black/white smoke,lift pump good doesn't cut out or misfire runs as it should other than putting fuel in the crankcase. THANKS.Does it blow black smoke like its getting to much fuel or does the crankcase just fill completely with diesel?
I agree.Listen to jd110. The engine is running fine and starting fine, that indicates that everything is fine in the combustion chamber, follow the evidence.
No,I changed the oil/filter and used maybe 1 hour since last post. I believe problem is with a bad seal in the injector pump.have you found/fixed yours yet?any resolution to this issue? I have a 2320 with the diesel in the oil.. Sample is at Blackstone for confirmation though
