Mowing 422 Brush Cutter Blade Bolt Broke Again
   / 422 Brush Cutter Blade Bolt Broke Again #21
I quit using the back stop bolt. Just another thing to break. So what's breaking is the bolt holding the blade on.
I notice that the new spacers are smaller in diameter than the old ones. Today I had a blade hang up (clear with a few hammer taps) and noticed that the washer was bent. This is the one I put on yesterday. The extra gap between the spacer and the blade puts more stress on the washer.I will start using grade 8 bolts and washers now. Maybe a double washer.
I still use the kick back bolts, I believe if memory is right I have only broken two of those bolts so it hasn't been an issue with me. I did use a longer bolt and a stack of washers on them to keep the blade from going back and hanging up on them. I am thankful that the bolts that hold the blades on has never broke on my machine, that is a scary thought.
   / 422 Brush Cutter Blade Bolt Broke Again #22
these are the reasons i switched to the disc style blades on my brush hog, cheaper to replace the blades when they ''exit stage left'', less mass =less energy when blades come loose, feel better knowing i was not the only owner to have problems with broken bolts/crossthreaded bolts etc.etc. for the jobs i encounter the cut quality is excellent
Do you have pictures and source for the disc style blades?
   / 422 Brush Cutter Blade Bolt Broke Again #24
Rob,
I think Washita has the conversion disc that mounts to the brush-hog. You remove the two large blades and replace it with a large disc that has about 6 short blades mounted around the outside circumference.
   / 422 Brush Cutter Blade Bolt Broke Again #25
I haven't lost any blades yet either. But then isn't anything worse then the occasional metal T post. When i first broke off the 'kick back' bolts, I use stacked washers or whatever i had available to stack on the 'kick back' bolts to help dampen the shock when the cutter blades hit them. I didn't use grade eight bolts. So far so good.
I am interested in that disk blade conversion though.
   / 422 Brush Cutter Blade Bolt Broke Again #27
Rob,
I have that kit also, but haven't used it yet. My understanding was that this kit converted the deck to a finish mower. I don't know how well it would work as a brush cutter...at a minimum, I would think the blades would get dulled and not work as well for finish cutting a lawn.
   / 422 Brush Cutter Blade Bolt Broke Again #28
The blade bolts break easily too, if you hit something. After breaking many bolts,
using it to cut brush, I added two bolts to each blade and that helped. However, now
I bent the disc that holds the blades. Something has to give, so I guess it is cheaper
in the long run to just keep replacing the two hold-down bolts.
A1 MIST SPRAYERS RESOURCES TX3PT LOT NUMBER 85 (A53084)
A1 MIST SPRAYERS...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2023 Bobcat E32i Excavator (A51573)
2023 Bobcat E32i...
UNUSED FUTURE FT1000J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2012 Nissan NV2500HD Cargo Van (A51692)
2012 Nissan...
