Mowing 422 Brush Cutter Blade Bolt Broke Again
   / 422 Brush Cutter Blade Bolt Broke Again #21
I quit using the back stop bolt. Just another thing to break. So what's breaking is the bolt holding the blade on.
I notice that the new spacers are smaller in diameter than the old ones. Today I had a blade hang up (clear with a few hammer taps) and noticed that the washer was bent. This is the one I put on yesterday. The extra gap between the spacer and the blade puts more stress on the washer.I will start using grade 8 bolts and washers now. Maybe a double washer.
I still use the kick back bolts, I believe if memory is right I have only broken two of those bolts so it hasn't been an issue with me. I did use a longer bolt and a stack of washers on them to keep the blade from going back and hanging up on them. I am thankful that the bolts that hold the blades on has never broke on my machine, that is a scary thought.
   / 422 Brush Cutter Blade Bolt Broke Again #22
these are the reasons i switched to the disc style blades on my brush hog, cheaper to replace the blades when they ''exit stage left'', less mass =less energy when blades come loose, feel better knowing i was not the only owner to have problems with broken bolts/crossthreaded bolts etc.etc. for the jobs i encounter the cut quality is excellent
Do you have pictures and source for the disc style blades?
   / 422 Brush Cutter Blade Bolt Broke Again #24
Rob,
I think Washita has the conversion disc that mounts to the brush-hog. You remove the two large blades and replace it with a large disc that has about 6 short blades mounted around the outside circumference.
   / 422 Brush Cutter Blade Bolt Broke Again #25
I haven't lost any blades yet either. But then isn't anything worse then the occasional metal T post. When i first broke off the 'kick back' bolts, I use stacked washers or whatever i had available to stack on the 'kick back' bolts to help dampen the shock when the cutter blades hit them. I didn't use grade eight bolts. So far so good.
I am interested in that disk blade conversion though.
   / 422 Brush Cutter Blade Bolt Broke Again #27
Rob,
I have that kit also, but haven't used it yet. My understanding was that this kit converted the deck to a finish mower. I don't know how well it would work as a brush cutter...at a minimum, I would think the blades would get dulled and not work as well for finish cutting a lawn.
   / 422 Brush Cutter Blade Bolt Broke Again #28
The blade bolts break easily too, if you hit something. After breaking many bolts,
using it to cut brush, I added two bolts to each blade and that helped. However, now
I bent the disc that holds the blades. Something has to give, so I guess it is cheaper
in the long run to just keep replacing the two hold-down bolts.
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
12 in Large Excavator Bucket (A52377)
12 in Large...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2023 DONDI DBR/75 S LOT NUMBER 54 (A53084)
2023 DONDI DBR/75...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
ALLIANCE 480/80R42 LOT NUMBER 134 (A53084)
ALLIANCE 480/80R42...
