425 Quit in 7 Degree Weather
   / 425 Quit in 7 Degree Weather #21
Replace the spark plugs. Cold weather will cause the engine to run colder. Older plugs will have a tendency to foul quicker. If this engine is using any oil at all, it will show up on the plugs in the winter.
TreeMonkey1000 - I couldn't find Peter 6-9? (It only goes to 5-14) - Did you mean 5-9. ... just curious...... BTW - thanks for the hairdryer tip.
   / 425 Quit in 7 Degree Weather #23
6 In this you greatly rejoice, though now for a little while you may have had to suffer grief in all kinds of trials. 7 These have come so that your faith-of greater worth than gold, which perishes even though refined by fire-may be proved genuine and may result in praise, glory and honor when Jesus Christ is revealed. 8 Though you have not seen him, you love him; and even though you do not see him now, you believe in him and are filled with an inexpressible and glorious joy, 9 for you are receiving the goal of your faith, the salvation of your souls.
Great word! (even though I still can't locate a 1st Peter 6 in my bible) , especially the part about trials and difficulties... I think we can all relate even if in just some small ways.
   / 425 Quit in 7 Degree Weather #25
Hmmm Lyle I am not sure where you are looking. That is out of the NIV bible. Your trials now are getting your carb thawed out. If you get that torn gasket fixed and the fumes have evaporated you might try the hair drier. See if there is a carb heating tube that is missing that flows warm air off the exhaust manifold to keep the carb from freezing. I know my truck did the same kind of thing. My chainsaws have a winter flap that pulls warm air from the crankcase to keep them from icing the carb up.
Ahh -- so that's the purpose of that funny little, hose (the diameter of a finger) curling up from the exhaust manifold and connecting to the air cleaner housing. I'll have to check on that and make sure it's properly positioned. So, I'll be off in search of my carb gasket tomorrow (while the carb gets all cozy and warm inside my house). Would you recommend gasket sealer in addition to the paper gasket?
BTW - My wife was quick to clarify that it's 1st Peter 1:6-9 , ....now if I can just get the old tractor to fire up so I can start digging out (almost 2' of snow here in Grand Rapids, MI).
Thanks for all of your help, and the help provided by everyone else who participated in this thread.
   / 425 Quit in 7 Degree Weather #27
Two things not mentioned--there is a fuel cut off solenoid that screws into the carbon some models. If it is bad, or shorted you may not be getting fuel,or very little fuel. Also, some of the early Kawasaki engines had nylon timing gear that had a tendency to crack an shed teeth. You can hope not, and to check, remove a valve cover to check for proper cam/valve activity. My mom would have said to pray for the solution, and I see you are on the right track!
Goatman
   / 425 Quit in 7 Degree Weather #28
Lyle,
I'm gonna suggest a different route for you. This sounds like a classic coil problem. Runs fine until hot, then dies. Next time it runs for 30min. and dies, put your hand on the coil - if it's hot to the touch, get a new one and go from there. I've had this happen to me before with a Kohler - it's 30 years old and I've never done anything with the carb. Not to say it isn't a carb problem, but it sure sounds like the coil to me.
Good Luck!
   / 425 Quit in 7 Degree Weather #29
He just forgot to put the chapter in there. It is chapter 1 verses 6-9
Mike
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
McFarlane 4030 Reel Disk (A59814)
McFarlane 4030...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
TANK MANIFOLD (A58214)
