425 starting problem.
/ 425 starting problem. #1
flightlogix
Union, Kentucky
I am unable to start my JD 425 s/n 090962 using the ignition switch. I installed a new ignition pc board and switch. Still nothing. If I set the parking brake, pto switch off and turn on the key, the battery light on instrument panel lights. The fuel pump will not run unless you sit on the seat. Tested the parking switch and I do have continuity with the brake engaged, but there is no voltage at the switch. I was able to jump the starter and the tractor ran perfect as long as I was in the seat. The pto engages, indicates on instrument panel and I was able to get the grass cut. Does anybody have any ideas? A wiring diagram would really help. Thanks, Greg
