430 Case (DB) rear wheel lock-up
   / 430 Case (DB) rear wheel lock-up #1
ducksjunk
Burks Falls, Ontario
yanmar 195D (for sale)
I have a case 430, that sat for about 5 months. when I tried to move it the right rear wheel wouldn't turn. Even on towing it stays put. there is a tiny amount of free play front to back when moving it but thaat's all. It wasn't parked with the brake on so I doubt that it is a siezed brake. a friend of mine has the same tractor and his does something similar but it always comes free. Is this a common complaint, and how do i resolve it?
thanks.
Richard.
   / 430 Case (DB) rear wheel lock-up #2
The only thought that comes to my mind is maybe the clutch plate is stuck to the flywheel. Happened to mine one time. I shifted into the lowest gear and fired it up. Of course it started moving, so make sure you have somewhere to go if it does. Then I ran it into the nearest convenient obstacle, over and over. It eventually broke loose.
Good luck to you.
Tom
   / 430 Case (DB) rear wheel lock-up #3
I agree with Marlow, I had the same thing happen to an old Oliver, I pushed in the clutch put it in gear and hit the starter and the tractor started to move. I ran it into a large tree several times as well, the clutch eventually broke loose.
   / 430 Case (DB) rear wheel lock-up #4
It isn't the clutch. Sounds like water in the outboard final drive that has frozen. Or is it in a nice, warm barn?
   / 430 Case (DB) rear wheel lock-up #5
Was the braked locked while it was sitting all that time? Sometimes brake linkage will stick, or the shoes "freeze" to the drums, or a dozen other things. Gonna have to figure out FOR SURE it's the brake stuck, then go to work on that. Once you're sure it isn't a rear end/final drive full of ice, try pulling it forward or reverse. Adjust the brake as loose as it will go. From there, it get's a little more involved.
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
