Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,823
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Saw some water dripping....so needed a new water pump. Decided to drain/replace the hydraulic fluid at same time. Tore into it today, got it done.
Oh, I might add that to warm up the hydraulic fluid, I went out to cut a couple swaths of grass.....so it WAS working and working fine.
Get done and now, jump on to start and when the lever is released such that the "little clicker" that it pushes against when you start it is released.....the engine stops.
The fuel shutoff solenoid is getting 12 volts but now that I'm typing this, I don't recall if that is when the forward/reverse lever is in the 'start' position or when it's released.
Connection under the seat is intact.
I DID notice a relay next to the fuel shutoff solenoid. I have a relay tester that was given to me so I don't know if it actually works. I put the relay into it and it DID show a fail.... then I saw some wisps of light smoke coming from inside the relay. So if it wasn't toast, it probably is now. I'm getting a new one.
If the relay DID die on me today, does that 5-blade relay control/effect the fuel shutoff solenoid?
Other than the wire under the seat, I didn't touch any wires today so I'm dumbfounded..... also.... the machine starts fine and roars as it should after I got done.....HOWEVER, it will ONLY run when I hold the forward/reverse lever in the 'start' position. Once I let it go, the engine dies. Both blade pto switches are also off.
Any thoughts??
Any thoughts??
