4310 and 74 inch front blade
   / 4310 and 74 inch front blade #1
Kubbruce
Vermont
L3010HST
I'm in process of trading in my two tractors to get one. I've deciced on the the 59 inch blower but I am also thinking about the 74 inch front blade. Does anyone know how long it takes to switch from the blower to the blade? We get an average of 500 inchs of snow per season. My driveway is about 1/4 mile long and I find having both very helpful at times. I've tried a rear blade but I'm not fond of pushing back wards. Any help that you can offer up would be great!
   / 4310 and 74 inch front blade #2
Turn the blade around and drive over the snow. If you have a quality rear blade you will not have a problem. If you need to push onto grass or somewhere that you don't want to dig in then you can just push with the rear of the blade. Works great for me. (I have a Land Pride RB3596 rear blade)
   / 4310 and 74 inch front blade #3
Yes, I agree.
We also get a lot of snow and I use a 4310 with a 6FT rear blade and an FEL.
I drive over the snow and use the rear blade. My blade is very heavy and does a great job of snow removal.
Richard
   / 4310 and 74 inch front blade #4
Bruce,
I have been involved in similar discussions recently. I assume, from your citing a 74 front blade, that you are looking at a mid frame John Deere tractor (4310 I think you mentioned). I live in Western NC and we do get a fair amount of snow generally, just not this year -- so far. I have a loader mounted front blade for my tractor and in the two snows we have had, it works great. I have used rear mounted blades in the past (and even have one now for grading) but would no longer consider it after trying my new boom mounted blade for snow removal. I assume you would also want a loader for your new machine. With your current request, you would have to remove the loader to put either of the attachments on. While several of my Northeast friends espouse the benefits of snowblowers, it seems one would have to have A LOT of snow on a regular basis to make one financially worthwhile. One alternative suggestion is to get a front end loader for your new tractor, outfit it with a front mounted blade, and buy a rear mounted aftermarket blower for those few times you may need one. You could, in theory, even run both the blade and blower simultaneously (of course not at once, that would be impossible). I have seen the standard 74 front blade for the John Deere tractors and my impression was it was not as easy to install and offered less flexibility than the boom mounted blade. My blade literally takes less than five minutes to install and works really well. It also lifts much higher, is easier to see because it sits further in front of the tractor and can be angled in multiple planes due to its being mounted on the loader arms. Although we have not gotten heavy snow this year, I see that it would take a tremendous amount of snowfall over a short time to make a blower more effective. In those rare instances maybe a rear blower would be your best option, in spite of their need to be used in reverse. I know the JD 59" front blowers are very pricey, unless you could find a used one. In the aftermath of the Blizzard 2005 in the NE, many people are reconsidering their snow removal options, but the reality is that snowfall, on average, is down in many areas, and one must consider attachments that have year round capability. I would be concerned that you could not purchase a 74 front blade and 59 snowblower for much less than you could a 300x or better loader with boom mounted blade AND rear mounted snow blower. I realize you have "decided" on the 59 snow blower, but consider these alternatives. These facts are independent of your main concern, mounting and dismounting times, which would definitely be some slower.
John M.
   / 4310 and 74 inch front blade #5
I am in the same boat here in Maine, I just purchased a 4310 with the 430 FEL and I am wondering about buying the 74" Front Blade or the blade that attaches to my loader. Using just the FEL 61"bucket takes a lot of clean up time and if your not carefull on a tar drive way you can dig it. It is cold in Maine and I want to cut back my out door freazing me to death time.
What did you decide and what was the best price you got on the 74" Blade or Blower?
   / 4310 and 74 inch front blade #6
I'd like to see a boom mounted Boss 8'2" power Vee. THAT would move some snow...
   / 4310 and 74 inch front blade #7
   / 4310 and 74 inch front blade #8
Who makes the best boom Blade and the best price, how big of a blade can I go with a 4310 4WD with the 430 FEL? Our local dealer sells Curtis only..
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
Deere 331G (A50123)
Deere 331G (A50123)
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51692)
2012 Trail-Eze...
2025 CFG Industrial 680 (A50123)
2025 CFG...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2017 Nissan Altima Sedan (A51694)
2017 Nissan Altima...
