4310 won't start
/ 4310 won't start #1
95fxdl
It started then died. We had a hard rain so I drained the fuel filter bowl since this has happened before. Now it will not start. if I leave the bowl loose it tries to run and when I tighten it , it does nothing.
Any help is appreciated, thanks, Dennis
/ 4310 won't start #2
"With the bowl loose it tries to run"...Sounds like I would start with a new fuel filter. It seem to try to run when you are letting fuel past the filter.
/ 4310 won't start #3
It sounds like you have air and or water in the fuel system. You can't have any air in the system. Read the manual on purging air in the fuel line.
