4320 Overheating
/ 4320 Overheating #1
DRod
SW Pennsylvania
JD 4320
Hey guys!
I have 1 1/2 year old JD 4320 with 300 hours which has recently started overheating. The first instance was during snowplow duty this winter at temps of 20 degrees or less. The needle would slowly creep higher, and once I got a "temphi" readout on the LCD display. The few times I used it this winter after that, keeping higher RPMs (2000+) on the engine seemed to help.
Fast forward to yesterday, when I went to get a little early brushogging in. After changing the oil, cleaning the primary air filter (dealer had to order in a new one - none in stock), and cleaning off the grill and radiator screen, I took it out again. The temp was climbing while I got the brushog mounted, but came down a little when I kicked up the RPMs (still staying on the top 1/2 of the gauge).
It stayed in the green, but high, while I was using the tractor. Idling for only a couple minutes to take a phone call, it went into the red and I got "temphi" again. Running it to get it back to the house, it dropped back into the green, but not by much. After shutting down, I checked the coolant in the overflow tank, and it was still cool, like it's not circulating.
Do you think this points to a thermostat problem, or am I missing something a little easier?
Thanks for the help.
/ 4320 Overheating #2
Remove the radiator cap and make sure the radiator is full (cool temp). Did you clean the radiator really good with compressed air? Next, make sure the belt (fan & water pump) is not too loose. If above is ok, I'd strongly suspect the thermostat.
/ 4320 Overheating #3
Something must be wrong. These tractors are not prone to overheating even on hot days and working hard. My 4520 with cab and a/c running never gets hot. Barely gets over the 1/2 region in the green. Really check you radiator. You may be plugged within the fins of the radiator and not on the surface. Run water (low pressure) through the radiator when the tractor is cool. Should be able to run through all portions will good flow out the backside.
It could be the thermostat but usually is another issue. Check the amount of fluid in the radiator and not just reservoir.
/ 4320 Overheating
Thanks for the advice guys - I'll check it out when the rain stops, and let you know how it goes.
Much appreciated!
Dale
/ 4320 Overheating #5
I'd put my guess at a loose fan belt, or low coolant in the radiator.
Fins shouldn't be plugged up on a 1 1/2 year old tractor, unless you've been cutting a lot of grass and it's getting sucked up into the radiator fins.
If you can't find an answer here, it's broke.:D
/ 4320 Overheating
Uh ... confession time.
Newbie thought that checking coolant in the overflow tank took care of things. Oops. Filled the radiator - all is better.
Thanks guys, for the help.
Dale
/ 4320 Overheating #7
Dale
Now you need to find out where it went...keep an eye on the level.
/ 4320 Overheating #8
Dale
Good news and bad news. Full overflow tank and low radiator should not happen unless something else is wrong. The radiator cap is the first thing I'd look for but a leaking gasket or hose could also cause this. Best thing is to keep a close eye on the coolant level in the radiator and overflow tank. Also look for slow leaks around hose clamps and engine seals/gaskets especially after the tractor sits for a day or more. Good luck.
/ 4320 Overheating #9
Dale
Been there, done that. I still overlook the simple solutions sometimes.
UNUSED JCT 60" PALLET FORKS (A65055)
UNUSED JCT 60"...
2019 FREIGHTLINER 122SD 6X4 T/A TRUCK TRACTOR (A67148)
2019 FREIGHTLINER...
2014 MERCEDES 2500 CARGO VAN (A67147)
2014 MERCEDES 2500...
2021 SANY SY26U EXCAVATOR (A63276)
2021 SANY SY26U...
1995 PONDEROSA 16' STOCK TRAILER (A64278)
1995 PONDEROSA 16'...
UNUSED FUTURE WS43-MINI HYD WOOD SPLITTER (A65055)
UNUSED FUTURE...
