4330 HST - No Power?
   / 4330 HST - No Power? #11
dknarnd said:
hayden...so are you saying the 4330 won't pull a light duty 6' brush hog on hills with hst? Really I think the power will be there it just may need a little help in the weight department up front to keep it down.
No, not at all. Sorry for being confusing.
All I'm saying is that an HST only consumes about 5% of the engine output. As a result, if you compare a geared tractor to the same model HST, there would only be a 5% difference in power available to do work, either pulling, mowing, or whatever your do. If that 5% difference renders you unable to do the work you want, then you probably picked too small a tractor.
I'd recommend you size the tractor to the work, then pick the transmission based on convenience and preference, not based on the fact that an HST robs a tiny bit more power than a geared transmission. I just don't think the power consumption difference matters in a any practical way.
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
Informational Lot - Financing (A55218)
Informational Lot...
UNUSED LANDHONOR MGB-72-44W 44" MINI GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
