4400 wheel locked
   / 4400 wheel locked #11
GB4400 have you had any luck yet freeing up your brakes? I got mine broke loose yesterday. I sprayed the shafts with some BD 7-77 let it soak for a few mins. I tapped on the shaft end towards the case gently with a med sized hammer a few times. I then took a pry bar then pryed between the bracket and the case using light pressure. I could see the bracket move in/out from the case about maybe 1/32 of an inch while tapping/prying and soaking it with spray. After 15-20 min of doing this and working the brakes,both sides freed up and started working. My best advice is take your time don't hit or pry to hard and use plenty of penet.spray.
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2 Electric Pressure Washers (A57454)
2 Electric...
Kubota Utility Cart (A59228)
Kubota Utility...
Leer Camper Shell (A57454)
Leer Camper Shell...
2016 Husqvarna YTA18542 42in Riding Mower (A56859)
2016 Husqvarna...
