445 - 2" receiver setup at rear hitch. Options?
   / 445 - 2" receiver setup at rear hitch. Options? #11
I forgot to take a picture and just hauled it to another building 30 miles away. It will be awhile now for the picture. If you have seen the 6 inch long 2 inch reciever pieces that's what I used. They were about $9.99 on sale but probably little more now. I think I just cut the head off a couple bolts and welded them on. I bolted it on top of the factory hitch. I think I may have used a big washer as a shim because my weld was to large to fit into factory hitch hole. It is pretty low this way but a hitch with a lift corrects that.
One time I moved a big boat (27 foot) inside on concrete. The jack wouldn't lower enough but was a swing jack. I kicked it to get onto the ball. And bent the factory hitch. I think I would have been fine but the sudden drop caused it to bend. Should have had a taller ball mount.
   / 445 - 2" receiver setup at rear hitch. Options? #12
If you don't weld, it can be clamped on with long bolts and strap iron like this picture of my 446 from 8 years ago:
And using square U Bolts like on my brush fork frame:
   / 445 - 2" receiver setup at rear hitch. Options? #13
I bought a straight reese hitch receiver section that had two mounting holes. One lined up with the tractor's and I drilled a matching hole for the second one. Worked like a charm. Could use any class III attachment, including a sleeve hitch. Used it for 20 years.
   / 445 - 2" receiver setup at rear hitch. Options? #15
I've seen a couple of pictures with a 2" receiver setup attached to the rear without a 3-pt hitch. I DO have the click-n-go system in place.
I've looked around, but can't find something that would hook up directly.
Here's a picture of one I found - but didn't know if it was commercially available, or just something that was fabbed up.
Thanks!
There are a few options available that could be made to work. A step bumper receiver plate would probably work. Harbor Freight also sells an "ATV Hitch Adaptor" that would bolt to the hitch pin location on most mowers.
ATV Hitch Adapter
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53472)
JOHN DEERE ROW...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
toro turf sweeper (A50324)
toro turf sweeper...
AMADAS SPC-6 LOT NUMBER 257 (A53084)
AMADAS SPC-6 LOT...
BROWN MPT-30 LOT NUMBER 67 (A53084)
BROWN MPT-30 LOT...
