445 won't start
   / 445 won't start #11
The camshaft gear is bad. They have plastic teeth. Pull cover and install new cam. It has gone out of time
He said it had the steel cam gear in it.
I would replace the engine just because it hasn't fired unless you have found a major issue. I would of thought it would of fired off if you sprays starting fluid in the spark plug hole though.
159115 (A60430)
159115 (A60430)
1999 Thompson H3 S/A Towable Vacuum Water Pump (A59228)
1999 Thompson H3...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
