4500 4x4 or 3510?
   / 4500 4x4 or 3510? #1
DirtyDusty
North Louisiana
New Holland TN75
Went looking at tractors the other day and trying to decide between a 3510 and a 4500. I have 15 acres that I just bought and need to bush hog and do a alot of grading and leveling. When I am through I will need to run a finish mower behind it. Will the 4500 be too big to put on a finished yard to mow? How will a 3510 pull a 6 foot medium duty bush hog and box blade? Could you pull small 6 or 8" stumps out with a 3510. I am considering betting the R4 tires will these work?
   / 4500 4x4 or 3510? #2
I have the 4110 and it does all that you ask and maybe a little more.. The 4500 in the future may be to big.. The 3510 miight not have enough pto power.. Look at the 4110 is my guess for a good all around need it and in the future tractor
   / 4500 4x4 or 3510? #3
Being currently up to my eyeballs in a Mahindra purchase, I'll share some related info I've learned.
3510 -> 4110 :
3cyl -> 4cyl
35hp -> 41hp
28hp PTO -> 33hp PTO
smaller back wheels -> larger back wheels
small front wheels -> much larger front wheels
In speaking with my dealer, an 84" finish mower is okay down to about 27hp PTO. (Not exactly your application, but should be able to correlate).
I opted for 3510, reasoning the PTO hp was okay for my most demanding implement, and the remaining hp was probably used to drive the much larger front wheels in the 4110.
I've looked at both (read: climbed all over, have brochures,etc). Same identical tractor except for engine and wheels, as far as I can tell. Dealer agrees.
CAUTION: 3510HST ("Hydrostatic 3510") is *NOT* a 3510 with hydro drive. It is more of a 2810 with a larger engine. about 2 feet shorter, around 800 or so pounds lighter, uses smaller loader, about 900lbs less lift capacity, but adds mid-mount mower up to 72".
I almost made the 3510HST mistake, figuring $1k was good price to up to hydro, but luckily found out about the big downgrade in tractor.
I also opted for R4 industrial tires. Not as turf damaging as Ag, more aggressive than turf. We run this same tread on our Case 580K backhoe with excellent results. Expecting same performance on this smaller CUT.
Hope some of this helps. Best advise is to READ, READ, climb all over, talk with dealer.
Good luck.
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
