4520 mfwd is a pain ti engage/disengage
   / 4520 mfwd is a pain ti engage/disengage #1
yukonhunter
leroy ny
John deere 5100m, mf1643 cab and kubota bx2370woods bb720x land pride disc and reverse tiller
Is there a special trick to it...it says just lift up and down , but seems very hard to do so????
   / 4520 mfwd is a pain ti engage/disengage #2
It helps if you move a little bit. Engaging is usually pretty trouble free, disengaging some times I back up a little or turn the wheels left and right. What kind of trouble are you having?
I have never noticed it being any worse than anything other 4WD vehicle.
   / 4520 mfwd is a pain ti engage/disengage #3
It is brand new give it some time to loosen up and as Arlen mentions a slight movement will help. This is true for the range selector too.
   / 4520 mfwd is a pain ti engage/disengage #4
This on a 3320, so yours may be different. I let off on the eHydro pedal, make sure the front wheels are pointing straight - engage or disengage. Works while still moving, but have only tried in maybe 1-3 mph range - not fast.
   / 4520 mfwd is a pain ti engage/disengage #5
arlen is spot on. as you use it more it will loosen up
Thx guys
   / 4520 mfwd is a pain ti engage/disengage #7
It works much better if the tractor is not on a hard surface - blacktop or concrete, otherwise there can be a tendency to bind up.
   / 4520 mfwd is a pain ti engage/disengage #8
If It does bind up, I like to pick the front wheels off the ground with the loader. Then it will slide in and out easily.
   / 4520 mfwd is a pain ti engage/disengage #9
Or when going slow, tap the throttle in a quick accel/decel fashion as you work the lever and the 4wd usually slips right out when when it's goes through that moment when it's not binding in either direction- like butter.
   / 4520 mfwd is a pain ti engage/disengage #10
I generally will change directions briefly (forward or reverse)... since I might not have the loader attached.
JOHN DEERE 920 FLEX GRAIN HEAD (A52708)
JOHN DEERE 920...
4ft Quick Attach Disc Harrow (A57454)
4ft Quick Attach...
2004 John Deere 310G 4x4 Loader Backhoe (A56857)
2004 John Deere...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
Adams 5T Pull-Type Fertilizer Spreader (A56436)
Adams 5T Pull-Type...
Snow Dogg 7.5' Snow Plow w/Bracket (A55272)
Snow Dogg 7.5'...
