4530 running rough/blue and white smoke - FYI
   / 4530 running rough/blue and white smoke - FYI #11
I only use #1 fuel from the pumps. I cringe when I see people pulling their trailered tractor up to the farm grade tank at my local store! That said, I'm still curious to find out where the trash came from that I found on my tank filter. Had to be coming through the vent in the cap. I clean around the neck before removing the cap every time. The fuel container is made sure to be clean before I fill it. And I don't leave the cap off any longer than it takes to add fuel. Go figure...
With the problem I originally posted about, the tractor actually ran worse the hotter it got, not better.
If it is black and a little looking like plastic it could be the tank lining. Not sure on the 4530's but there was a small run of models where the lining on the tank came loose. Mahindra generally fixed all for us.
Bill
Bill
No, it was more brownish/greenish and appeared, as best I could tell, to be organic. I think it was just an accumulation of the fine grass particles that find their way into everything. The same stuff you get around your grease fittings (or at least I do).
   / 4530 running rough/blue and white smoke - FYI #13
For what it's worth I ran into this problem on my <50 hr 3525 and it was air on the suction side of the injector pump. I found that the water seperator hose connections are pressed in and they were not air tight. I took off the seperator and cleaned the area where the hose connections are with carb cleaner. I then used good ole JB weld to seal them up for good. Now it runs like a champ. If you see any air in your water seperators you have an air leak. Trust me it took me a while to figure this one out. I would run a while just fine then... just as in the first post here.
Good luck, hope this helps.
   / 4530 running rough/blue and white smoke - FYI #14
CD,
I learned about the filter screen the hard way, as you did. At the time, I was not convinced that was what really fixed my "running rough" problem. I kept checking for air on the lines, filter seating, water in the fuel, etc. However, I have learned that if I clean the screen every 50-60 hours, I have no problems with the engine.
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2006 TerraGator 8104 (A52748)
2006 TerraGator...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2008 Bobcat S250 Skidloader (RUNS) (A50774)
2008 Bobcat S250...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
