45hp HST tractor and a plow
   / 45hp HST tractor and a plow #1
fishpick
Platinum Member
The part of NY with high taxes
L4760 & BX24
(I posted this in the NH forum - then realized it's more of a "general tractor question")
I have a TC45DA.
Question for the folks who own a similar sized tractor: How big of a plow does you tractor pull?
I have the opportunity to buy a 3 bottom plow or a 2 bottom plow. Want to go big - but not too big (of course I could always remove one bottom from the 3).
My TC45 has ag tires and the rear is loaded (it's 4WD - obviously). Soil around these parts is pretty sandy. Rocks are round and the biggest is no bigger than a Nerf football. Little BX24 Kubota pulled a 1 bottom in these parts with no issue at all unless things were wet and the R4's loaded up.
   / 45hp HST tractor and a plow #2
I have a 33 PTO HP tractor (2810 Ford from 1987) that weighs about 4700 lbs. It has 13.6 by 28 inch Ag tires, loaded, 2WD. I pull a 2 bottom 14" plow with no problems. If the dirt is wet enough for the plow to go in, I can pull it okay. Our Franklin County, VA soil is rocky brownish red to red clay with a little sand mixed in. It gets very hard after 6 or 8 months of non tillage. I doubt if I could pull 3 bottoms. Hope this helps.
   / 45hp HST tractor and a plow #3
I have a DX55 and recently purchased an old Ford 3 bottom 14" plow. I removed 1bottom, replaced the wear parts on the other 2, and it plows great. But I would not be able to plow with a 3 bottom in my mixed clay soil. At least not plow at the 4mph speed needed to roll the soil. Also, I am usually powing down a cover crop which doesn't help.
   / 45hp HST tractor and a plow #4
If the condition and price are comparable buy the 3 bottom. As you have already stated, could remove one. With the right conditions 3will be easy. Years ago we used 3x16 behind a Ford 3000, done a good job except when the operator,me, got stupid with it,I was young and in a hurry. scrapironford
   / 45hp HST tractor and a plow #5
I would go with the 3 bottom. I have a 43hp tractor with r4 tires and have pulled a 3-bottom 14in plow with little problem when the ground is just right. You have loaded r1 tires so you shouldn't have any problem.
   / 45hp HST tractor and a plow #6
I have a 34hp Kubota and non-loaded R4's. It's about all the work the tractor wants pulling a 2 bottom 14" Dearborn. That is in clay soil with a good amount of root still in the ground (reclaiming an old overgrown field).
Kubota SVL95-2 High Flow Cab Skid Steer (A51039)
Kubota SVL95-2...
2021 John Deere R4038 Self Propelled Sprayer (A50657)
2021 John Deere...
2010 Case 660 Trencher (A50322)
2010 Case 660...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A51039)
2014 Ford F550 4x4...
2014 New Holland T8.360 MFWD Tractor (A51039)
2014 New Holland...
