4600 ford tractor
   / 4600 ford tractor #1
sirfixalot
Blountville, tn
ford 4600
I have a 4600 ford diesel tractor gaining oil. It's not colored,muddy, smells like diesel. I've been told that i have a fuel injector leaking. is there anything else could cause that to happen.
   / 4600 ford tractor #2
Could be the fuel lift pump. If the diaphram has a hole in it fuel can leak past the pump directly into the base.
   / 4600 ford tractor #3
No lift pump on a 4600. Could be a fuel injector, injector pump shaft seals, or less likely a failed thermostart unit. Could also be a failed power steering pump, but that would not smell like diesel.
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2011 Liebherr L586 Wheel Loader (A55218)
2011 Liebherr L586...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
