4600 won't start?
/ 4600 won't start? #1
IslandManMitch
Bronze Member
Pineywoods of Florida
John Deere 4600
I bought my 4600 used a couple of years ago and the original owner told me sometime when it won't start you have to crack an injector line. I ran it for months and one day it would not start, crack injector line and she started. Over the past couple of years it has happened off and on and sometimes I would have to crack a couple of lines. It might happen the day after using it or maybe a month with no rhyme or reason. Today cracking the lines don't work. No fuel to the injectors. I checked all the rubber lines and fuel flows through them. The system is supposed to be self bleeding? Any ideas what the problem may be? Mitch
/ 4600 won't start? #4
If you are getting a good flow of fuel to the injection pump and no fuel to the injectors, it has to be either a bad injection pump or the fuel shut-off solenoid is not engaging. Do you hear the solenoid engage when you turn on the key? If not , then check for voltage to the solenoid. You could have a broken wire, blown fuse, or a bad relay. You also could have a bad thermistor. Check out this link: http://www.tractorbynet.com/forums/...ere-4400-hard-start.html?highlight=thermistor
/ 4600 won't start?
The solenoid is clicking but may not be fully engaging. I will try trouble shooting it tomorrow and hope it is the thermister. I thought injector pumps either worked or not? Or they get weak over time and not supply enough fuel pressure?
/ 4600 won't start?
OK problem solved! Thanks JD110 for the information that lead to my solution. That Green Thing is back up and running.
/ 4600 won't start? #7
Thats great to hear! So in the end, what was the solution? How much did it cost to fix and how long did it take?
