4610 su ford wiring
   / 4610 su ford wiring #1
peatley
bethel, ohio
ford 4610 su
I'm new and I need directions for wiring ignition switch on Ford 4610 su diesel.
I have some thing wired wrong and runs battery dead.
   / 4610 su ford wiring #3
Try reposting your question in the New Holland / Ford forum (owning & operating). Several resident Ford experts who are frequent posters monitor that forum, and I am sure they will come along and offer suggestions.
Welcome aboard.
   / 4610 su ford wiring #4
Welcome to TBN from Oklahoma.
Ken
   / 4610 su ford wiring #6
Welcome to TBN :)
I moved your thread to the Ford/New Holland Owning & Operating Forum.
   / 4610 su ford wiring #7
do you have a service manual? schematics are in there.
otherwise.. you will have many positions that can become hot from the main feed.. otherwise when off.. none of the other connecions should be hot. kinda basic description.. but 1 in.. many outs.
   / 4610 su ford wiring #8
A few questions. Are you installing a new ignition switch because of the battery drain? If so you may want to make sure you check the wires from the starter, alternator and light switch to make sure you do not have any places the insulation has rubbed through or connectors touching and grounding out. They don't cover that one in the manuals.
7ft Workbench (A57454)
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2018 International DuraStar 4300 18ft. Reefer Box Truck (A56858)
2018 International...
LOT OF 12' FLAT IRON (A58374)
LOT OF 12' FLAT...
2015 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52709)
2015 CATERPILLAR...
Toro Mower (A56857)
Toro Mower (A56857)
