467 John Deere Baler problem
/ 467 John Deere Baler problem #1
BALER
FORNEY, TEXAS
JOHN DEERE 6410
Help my door latch starts to open when I start rolling hay. Any help would be great
/ 467 John Deere Baler problem #2
On my 335, if hay is pretty dry, there will be a build up of finer chaff in the back loop, and drops under the bottom roller bar. When I close the door, there is enough pressure on the hydraulics, to kick it back to the neutral position. But yet, the door is not completely closed, or belts tight, once the PTO is re-engaged.
I just got in the habit of starting the baler at low rpm's, then nudge the hydraulic control to close again. Mine has the manual bale size indicator. I can tell when it starts building up, because it will not go completely back to where it should be. With PTO engaged, and nudge the hydraulics, the indicator will jump to where it should, and belts are tight, and door closed.
In extremely dry hay, I'll clean it every 15-20 bales.
2021 Ford Explorer AWD SUV (A66738)
2021 Ford Explorer...
2006 7X12 Lark S/A Enclosed Cargo Trailer (A66738)
2006 7X12 Lark S/A...
TOTE OF HEAVYEQUIPMENT HOSES (A68842)
TOTE OF...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
Unused 2024 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024 Land...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
