47" snowblower 2nd stage position bolts
   / 47" snowblower 2nd stage position bolts #1
tkoza
sch'dy, ny
jd 1026r
has anyone changed the (2) allen bolts to #8 bolts to allow for easier maint. and positioning of the 2nd stage auger on the rotating shaft
My allens were always coming loose
I switched to #8 bolts and lock washers for this season
   / 47" snowblower 2nd stage position bolts #2
We've used locktite there before.
we have also used some 1' split
locking collars to prevent the auger
from sliding forward and interfering with
the housing.
i would think they would redesign that,
or at least put the set screw on the key.
we have made impressions in the shaft for
the set screws also.
dutch 455
what did you use to indent the shafts???
i plan to disassemble the unit next spring and send it out for power coat
overall not bad from a unit i purchased in 1993
   / 47" snowblower 2nd stage position bolts #4
I think we just ground down a little
bit of a flat spot, that the set screw
could bite better, and it gave it a lip
that it couldn't slide forward so easy
   / 47" snowblower 2nd stage position bolts #5
Dutch / tkoza:
Are you guys talking about the set screws in this pic?
Or are you talking about the other end of the shaft with the impeller on it?
You can see in this pic that one of the set screws is on the key, but the screws have square heads.
I'll have to check the front end on mine.
   / 47" snowblower 2nd stage position bolts #6
I'm referring to the allen screws in front of
the Impellar, they have a tendency to come
loose and let the impellar slide forward on the
shaft.
c&d
correct the set screws on the front
what year is the unit in the pic?
as the square head bolts could be an answer
tkoza
   / 47" snowblower 2nd stage position bolts #8
Thanks guys.
I posted in another thread about the gear in the pic moving on the shaft. Since the gear on the rear of the shaft shifted, I need to check the set screws in the front.
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
GEHL RT175 GEN 3 SKID STEER (A52707)
GEHL RT175 GEN 3...
2007 Ford Five Hundred SEL Sedan (A55853)
2007 Ford Five...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2015 FREIGHTLINER...
Genie GS-1930 19ft Electric Scissor Lift (A55851)
Genie GS-1930 19ft...
Deere 331G (A53317)
Deere 331G (A53317)
