4700 or 5210?
   / 4700 or 5210? #11
Re: 4700 or 5210? John Miller III
PC 2228-870, 970 AND 1070 COMPACT UTILITY TRACTORS HYDRAULICS
REAR AUXILIARY LINK KIT
8 9 0
7 7 7
KEY PART NO. PART NAME QTY SERIAL NO. 0 0 0 REMARKS
1 19M7881 SCREW 1 M8 X 20 (HS, HEAD MARKED 10.9)
12M7065 LOCK WASHER 1 8.100 MM
2 AM876687 CLAMP 1 (INCLUDES M802950)
3 AM877598 HYDRAULIC LINE 1 PRESSURE
4 19M7162 CAP SCREW 2 M8 X 16
12M7065 LOCK WASHER 2 8.100 MM
5 AM108399 BRACKET 1 X
AM108400 BRACKET 1 X X (SUB FOR M804943)
6 M72810 LABEL 1 (E)
M76402 LABEL 1 (F)
M93620 LABEL 1 (G)
7 ........ BRACKET NA (NOT USED THIS APPLICATION)
8 24M7051 WASHER 1 21 X 37 X 3 MM
9 T78716 NUT 1
10 AM105465 HYDRAULIC HOSE 1
11 R26375 O-RING 2
12 AM105467 INTERNAL HALF COUPLER 1
13 AM105466 HYD. QUICK-CONNECT COUPLE 1 (USED ON TRACTOR WITHOUT SCV)
14 M42702 SNAP RING 1
15 T77857 O-RING 1
16 M804944 SUPPORT 1
17 14M7273 NUT 2 M8
18 19M7646 CAP SCREW 2 M14 X 25
12M7068 LOCK WASHER 2 14.200 MM
19 AM877599 HYDRAULIC LINE 1
20 M800848 GASKET 4
21 M800853 BOLT 2
22 AM877597 HYDRAULIC LINE 1
23 M802950 CLAMP 1
.. BM18010 KIT 1 REAR AUXILIARY HYDRAULIC, (SUB FOR
AM108271)
(E) ENGLISH/ANGLAIS/ENGLISCH
(F) FRENCH/FRANCAIS/FRANZOESISCH
(G) GERMAN/ALLEMAND/DEUTSCH
{Sorry Russ, not ignoring you… I just saw your post…Ooops}
   / 4700 or 5210? #12
SCV VALVE AND LINES
KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
1 CH11985 KNOB 1
2 AM877617 LEVER 1 SCV CONTROL
3 19M7881 SCREW 3 M8 X 20 (HS, HEAD MARKED 10.9)
12M7065 LOCK WASHER 3 8.100 MM
4 M800853 BOLT 10
5 M800848 GASKET 20
6 12M7065 LOCK WASHER 3 8.100 MM
7 19M7185 CAP SCREW 3 M8 X 60
8 AM877608 VALVE 1 (SUB AM117015, AM117498, M803644, 19M7077,
24M7054, (2) M803681, (2) 11M7076, (4)
19M7560 AND (5) 12M7066)
9 AM877614 LINE 1 PRESSURE
10 AR21839 CLAMP 5 (SUB FOR M800675)
11 M801935 CLAMP 5
12 AM877615 LINE 1
13 AM876687 CLAMP 1
14 19M8425 CAP SCREW 5 M6 X 16 (HS, HEAD MARKED 10.9)
12M7006 LOCK WASHER 5 6.100 MM
15 M804968 COVER 1 LEVER GUIDE
16 M804967 SUPPORT 1 CLAMP
17 15H275 PIPE PLUG 1 1/4"
18 AM877610 LINE 1 PRESSURE
19 AM877612 LINE 1 PRESSURE
20 AM877613 LINE 1 PRESSURE
21 AM877611 LINE 1 PRESSURE
22 19M7938 CAP SCREW 5 M10 X 20 (HS, HEAD MARKED 10.9)
12M7066 LOCK WASHER 5 10.200 MM
23 AM877616 LINE 1 SUCTION
24 AM877618 BRACKET 1 SCV
25 AM877619 BRACKET 1 SCV COUPLER
AM878210 BRACKET 1 (870 DRAFT SENSING VERSION; 1070 CREEPER
VERSION)
26 14M7273 NUT 2 M8
27 M804966 SUPPORT 1 SCV COUPLER
28 19M7881 SCREW 2 M8 X 20 (HS, HEAD MARKED 10.9)
24M7055 WASHER 2 8.400 X 16 X 1.600 MM
29 M803679 LABEL 1 SCV COUPLER
30 M90604 LABEL 1 SCV LEVER (SUB FOR M803677)
31 M803678 LABEL 1 SCV LOCK
32 M805108 CLAMP 1
AM877720 CLAMP 1 (W/WELDED NUT)
33 19M7881 SCREW 1 M8 X 20 (HS, HEAD MARKED 10.9)
24M7055 WASHER 1 8.400 X 16 X 1.600 MM
34 M42702 SNAP RING 4
35 AM105466 HYD. QUICK-CONNECT COUPLE 4 3/8" FEMALE
36 ET15511 CAP 4
37 R26375 O-RING 4
CH13731 PACKING 4 (870 DRAFT SENSING VERSION; 1070 CREEPER
VERSION)
   / 4700 or 5210? #13
Thanks John,
That ought to be enough to get me in trouble /w3tcompact/icons/smile.gif
Russ
   / 4700 or 5210? #14
Patton - I would appreciate any information that you can share on the "Dale Phillips" brush hog - sounds like what I am looking for. I need to find out if they have a dealer in Colorado. Thanks - Garry
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A55973)
2012 Chevrolet...
2014 Ford F-350 (A55973)
2014 Ford F-350...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
1964 Mercedes-Benz 190D Car Sedan (A56859)
1964 Mercedes-Benz...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
