4710 JD steering cylinder broken
   / 4710 JD steering cylinder broken #1
garynn2
John Deere 4710 and 425
Hi
I have a 4710 JD compact tractor that I ran into a piece of wood and snapped the rod on the steering cylinder. I'm looking for information on it and having difficulty. I have the JD repair manual and have looked on JD's parts website but not enough info there. The manual says it is a non repairable cylinder but JD wants $800.00 and aftermarket wants $400.00 so I'm trying to see if it's possible to do it a little less expensive. The JD part number is LVA14158. I'm going to try and post some pictures with this and info from the parts site.
Part Details
Part Number: LVA14158
Part Price: 804.00 USD
On Hand: 1 Check Other Stores
Description: CYLINDER, STEER 45X22 (LG)
All Makes Parts from John Deere Where Used
English Metric
Specification
Weight 12.32 LBS 5.59 Kg
Bore Diameter 1.772 IN
Rod Diameter 0.866 IN
Stroke 12.929 IN
Closed Length 20.550 IN
End Type-Rod & Cap 0707
Rod End Size 0.625 IN
Cap End Size 0.625 IN
Working Pressure 0.00 PSI
Finish K
Note
I'm hoping the pictures are ok as this is the first time I've posted on this site.
There are two notches 180 degrees apart on the ring but they don't go very deep. It didn't seem to me deep enough for a wrench to hold on to and maybe there is some thought as to whether there is to much damage to it. I have looked at another post that had the same problem but needed more info also.
Thank You for all Help
Gary
   / 4710 JD steering cylinder broken #2
Take it to a hydraulic repair shop ... They'll either be able to repair it or tell you who can.
$800 is a lot of labor time.:)
   / 4710 JD steering cylinder broken #3
Welcome to TBN:)
A good hydraulic shop is your best option, the cap is welded on and would have to be removed in a lathe, then a new rod made, install new seals then re-weld. If you can find a replacement for $400, that is your best option.
   / 4710 JD steering cylinder broken #4
A lot of people want to spend your money, but if you have the skills, or a welder, one can fab up a cyl you may find at Surplus Hyd and have a welder attach the swivel and pins for much less.
If you can't do this or do not want to, or don't have the time, then there is only one choice, and that is to bite the bullet.
2009 Kubota RTV1140 (A57148)
2009 Kubota...
HARD TOP FOR CONVERTABLE CAR (A58374)
HARD TOP FOR...
CASE IH 1064 - 6R CORN HEAD (A52708)
CASE IH 1064 - 6R...
2013 Yamaha Golf Cart (A57453)
2013 Yamaha Golf...
LOT: (5) Bolt Cutters (A59076)
LOT: (5) Bolt...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
