4710 transmission repair costs
   / 4710 transmission repair costs #1
coachlickiss
Indianola, IA
Deere 4710
I would really like to have a 4710-20 but funding is problematic. Local dealer has a 4710 Power Reverser (my desired trans) with a cab and 800 hours for $13,000 asking. Have not seen it in person, but the note "hi transmission out" appears on the listing. Obviously this is a fixer upper, but it seems with the low hours and cab that it might be worth a look.
Any ideas on a best to worst case repair cost range?
Thanks in advance for the great responses, the knowledge and experience base here is very respected.
Kurt
   / 4710 transmission repair costs #2
Welcome to TBN:D
Seems odd that the dealer would not fix it if it was a simple repair? No idea what it could cost to fix it...
   / 4710 transmission repair costs #3
High Range out? Doubt if that's a simple repair (or cheap). Odds are, if the transmission is broken (see last comment in this post), the tractor will probably require splitting.
However, unless you run your machine on the road, you may never use high range.
I wonder if this 4710 was a rental machine? I have read (on TBN) that some rental yards blocked out high range for safety's sake.
   / 4710 transmission repair costs #4
Good thought-that would be great if that was the case! There was a "rental upgrade" kit that included the high range lockout as well as some other guards.
For arguments sake, how would I identify a "Rental kit" modded machine? In the event the dealership overlooked this.
   / 4710 transmission repair costs #6
I have no idea...I would think it would just be a plate or bracket to prevent the range shifter from moving into the high range position.
The dealer can look this up, I should think...
   / 4710 transmission repair costs #7
I looked in jdparts, but could not find the kits listed.
2014 Ford F-150 Ext. Cab Pickup Truck (A52377)
2014 Ford F-150...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
Ford F-450 Utility Truck (A55218)
Ford F-450 Utility...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2017 Ram 4500 Bucket Truck (A55218)
2017 Ram 4500...
