4720 Tie Rod End worn out at only 370hrs
   / 4720 Tie Rod End worn out at only 370hrs #1
Brown Dog
Veteran Member
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
The short tie rod end is extremely loose at right wheel.
Nut is tight.
Left side has no loose motion.
It's hard to believe its worn out already.
My 4700 has 1,690 hrs & still tight.
   / 4720 Tie Rod End worn out at only 370hrs #2
Is the 4700 a greasable one?
Mine are tight on my 4720 after 700 hours, but I wish I could grease them (I think?)
Maybe the nut was a little loose from the factory and the slop wallowed it out?
The 4700 IS greasable.
The 4720 is NOT :-(
I only Mow with 4720 / 110" RFM & Absolutely LOVE the Hydro-Trans for mowing but didn't think I would when I first bought it.
Fine Machine it IS !!!
   / 4720 Tie Rod End worn out at only 370hrs #4
Just checked my 4520 and it is tight with over 1000 hrs use. If it is loose enough to be an issue I would change it out.
My JD dealer said part # LVA14959 $175
WHOA !!!
My Napa dealer couldn't interchange the # but said he could prolly get one by the dimensions.
   / 4720 Tie Rod End worn out at only 370hrs #6
WHOA !!!
:eek:
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
Heavy Duty Skid Steer Post Driver (New/Unused)(Est. Retail Value $4,900). (A59225)
Heavy Duty Skid...
2016 Hyundai Sonata (A56859)
2016 Hyundai...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
Case 1020 25ft Draper Head (A56436)
Case 1020 25ft...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
