4720 Tie Rod End worn out at only 370hrs
   / 4720 Tie Rod End worn out at only 370hrs #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
The short tie rod end is extremely loose at right wheel.
Nut is tight.
Left side has no loose motion.
It's hard to believe its worn out already.
My 4700 has 1,690 hrs & still tight.
   / 4720 Tie Rod End worn out at only 370hrs #2
Is the 4700 a greasable one?
Mine are tight on my 4720 after 700 hours, but I wish I could grease them (I think?)
Maybe the nut was a little loose from the factory and the slop wallowed it out?
The 4700 IS greasable.
The 4720 is NOT :-(
I only Mow with 4720 / 110" RFM & Absolutely LOVE the Hydro-Trans for mowing but didn't think I would when I first bought it.
Fine Machine it IS !!!
   / 4720 Tie Rod End worn out at only 370hrs #4
Just checked my 4520 and it is tight with over 1000 hrs use. If it is loose enough to be an issue I would change it out.
My JD dealer said part # LVA14959 $175
WHOA !!!
My Napa dealer couldn't interchange the # but said he could prolly get one by the dimensions.
   / 4720 Tie Rod End worn out at only 370hrs #6
WHOA !!!
:eek:
Jisan Heavy Duty CAT345 72in Excavator Bucket (New/Unused) (A59225)
Jisan Heavy Duty...
JOHN DEERE HAY CUTTER (A58216)
JOHN DEERE HAY...
2020 ASV RT-120 FORESTRY SKID STEER (A52709)
2020 ASV RT-120...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
Toyota LPG 7FGCU20 3,400 lb. Capacity Forklift, S/N 86163, Dual Mast, Tilt, 80" Reach, 19,871 Hours (A59076)
Toyota LPG 7FGCU20...
2020 Hyundai Santa Fe SUV (A56859)
2020 Hyundai Santa...
