49 8N runs good after warmed up dont
   / 49 8N runs good after warmed up dont #11
well.. lets clear a few things up here.
1, the vreg. it has NOTHING to do with the ignition system. you can cut the wires to the vreg and throw it as far as you can out into the field.. and the tractor will still run.
2, oil pressure is directly related to engine rpm.. as the engine stalls.. oil pressure goes down to nothing.. that's physics, and normal.
3, carb starved of air? so you use choke? that's BACKWARDS.. choke FURTHER closes off air to the carb thus making it pull more fuel. if the carb was truly starved of air, like with a plugged breather, it would ALREADY be running like it was choked, and running rich. if you think it's starved of air.. slip the air clener tube off a bit. but if ADDING choke helps.. then it ain't starved of air.
4, governor.. it tries to maintain an rpm based upon load based on where you have the hand throttle set. it won't cause the machine to stall. can effect how it runs under load though.
you need to check spark at moment of stall. if you still have good blue spark at stall, then you need to address fuel issues.
soundguy
Thank you Soundguy, It seems to be fixed, back to your first reply (GAS) I got to thinking and pulled the carb off and got a rebuild kit, when i pulled it apart it was full of rust, the bowl was all rusty, most of the holes had rust around them. So cleaned it out rebuilt it, put it back together, started it up, purrs like a kitten, better then when I bought it. I think I may have to find a gas station that sells gas without ethanol in it.
Thank you again, Todd
   / 49 8N runs good after warmed up dont #13
av gas and marina gas likely don't have ethanol. or you can use a stabilizer.
soundguy
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
2023 KOMATSU WA480-8 LOADER (A51242)
2023 KOMATSU...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
UNUSED JCT QUICK ATTACH 84" GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
2016 KUBOTA RTV-X900 UTV (A51242)
2016 KUBOTA...
Unused Delta Crash...
