4944 How big of a brush hog can i run?
   / 4944 How big of a brush hog can i run? #11
R4944hst - run a 6' with no problems
i only paid 14,100 for it brand new 2009 left over :)
   / 4944 How big of a brush hog can i run? #13
I have a 4340 with 43hp and I use an 8 foot HD cutter.... My tractor runs the mower just fine.... but...... The mower is 2 foot wider than my tractor. I have found this to be a problem on uneven ground. The outside edges tend to dig into the ground.... Therefore I would not get a mower that is much wider than your tractor. A 6ft would have been a better choice for me..... I think this is more important than HP...
Not sure I agree with your last statement, but I do understand why you said it. In your case, you have a little more uneven ground around you then other folks. In my case, the width of the mower really doesn't matter, as long as I don't try to wiggle thru some trees with the tractor that a wider mower won't make. Everything I mow is on the level, so even if I run a batwing, or a ten foot wide mower, it doesn't matter. Seems the O/P might want to consider both reasons, if he has 40 acres to keep mowed.
David from jax
1996 FORD F SERIES DUMP TRUCK (A51406)
1996 FORD F SERIES...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
