4WD engagement difficult
   / 4WD engagement difficult #11
I had the same problem with my 4wd 'bota 5030. Then I read the manual... it says to be stopped, gently press the lever to go into/out of 4wd, continue pressing while rotating the front wheels from stop to stop... right then left. Somewhere along the line it slips like a knife thru hot butter into gear. Of course, clutch is depressed during whole process.
That's what works for me.
   / 4WD engagement difficult #12
I even have this problem the transmission in neutral. I told the wife a few times. If it doesn't engage easily to rock the pedal a bit to get it engages. Same thing with the 4wd.
Love HST just the same even if this is what it takes.
   / 4WD engagement difficult #13
The manual on my L4400 also says to turn the front wheels a little with the steering wheel. Works like a charm.
   / 4WD engagement difficult #14
Rusty said:
My B7500 HSD seems to engage into front wheel drive better while the tractor is moving. However, I just checked the Operator's Manual, and it says, "Use the lever to engage the front wheels with the tractor stopped." and "IMPORTANT: Depress the clutch pedal before engaging the front wheel drive lever." Whoops, I don't remember reading that before. :(
I engage and disengage 4wd on my BX1500 anytime I want while moving - - which is about 96.014% of the times. The only time I would even think of worrying about it is when moving briskly while turning. The system is working perfectly at 1000+ Hrs. I tend to test things out by feel and make my own decisions on some of the admonitions in operators manuals. Some of them are plain silly. Engaging stationary will sometimes butt gearteeth head on and it wont go in.
Larry
   / 4WD engagement difficult #15
I can shift mine while moving too and the manual only says not to do so if driving at higher speeds. But the point of the original post is that his tractor is hard to engage in 4wd. Are you suggesting that the solution is to do it while moving?
Thank you for all of your posts. N80 makes a point that I should probably clarify.
It has indeed be hard for me to shift into 4wd, but I have been doing so while stationary and have not tried turning the steering wheel. My assumption is that these remedies will help. It appears that I have been doing this wrong all along. I have never had an owners manual, so I have been learning by trial and error...and TBN.
Thanks again for your help. I will post my finidngs when I get some more seat time this weekend.
   / 4WD engagement difficult #17
Yes. I just went out and checked mine. It is difficult/impossible to get in 4wd sometimes when it is sitting still. It had been so long since I developed whatever procedure I use that I had forgotten about it. Thinking about it my Mahindra and larger Kubota seem to usually go right in sitting still. - - Whatever- I just do what works. The feedback from the levers has remained compatible with my concept of what is going on so I dont get worried.
Larry
   / 4WD engagement difficult #18
Ken_CT said:
I have the BX23 and often have to move forward or backwards a bit for the 4wd to engage. It often needs to be persuaded to engage. I don't think there is anything wrong. Just rock the HST pedal back and forth a little and it should go in.
Ditto.
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A53473)
Kuhns AE10 Small...
2008 Doosan Mega250-V Articulated Wheel Loader (A52377)
2008 Doosan...
2016 HINO 195 16FT BOX TRUCK (A54607)
2016 HINO 195 16FT...
33ft Dovetail Flatbed Trailer (A53473)
33ft Dovetail...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
