4wd engagement
   / 4wd engagement #1
arksdad
Bronze Member
PA
IH656 - NH T2310 - Country Clipper 60" ZTR
I have a T2310. What is the trick to getting it in and out of 4wd. It's a struggle either way
   / 4wd engagement #2
If you have a loader, raise the front wheels off the ground and it goes in/out like greased lightnin'.:D
   / 4wd engagement
Thanks Jinman, I'll give that a try!
   / 4wd engagement #4
Otherwise, try driving straight ahead and bumping the throttle while applying pressure to the shift lever. The throttle bumping will momentary release pressure on the drive gears. Driving straight will assure no pressure from the differential.
   / 4wd engagement #5
Yup..
   / 4wd engagement #6
Engage and disengage while moving straight. To disengage, 1st accelerate briefly full power - then let off quickly while simultaneously operating the lever.
larry
2000 Genie Z45/25 Manlift (NOT RUNNING) (A50774)
2000 Genie Z45/25...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2017 FREIGHTLINER...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2017 Ram 4500 Bucket Truck (A52748)
2017 Ram 4500...
