rbargeron
Elite Member
No, it's anything but obvious. The drawing in the L355ss WSM is vague about the number of collars/washers on each side of the double gear. But interestingly the L345 illustrated parts list shows a version with 3 collars, and includes an alternate version with 4. :confused2:
Up to a certain serial no. they use a thick one 22 and a thin one 23 on the same side - with another thick one 22 between the gear and bearing. In the inset they show a newer version with 4 - one 22 and three 23's. The parts list calls 22 a thrust collar and 23 a washer. They don't list different versions of snap ring 11.
A couple ideas - these are not helical gears so they have very little end thrust. I wouldn't be very concerned about using a thinner snap ring. I also wouldn't be shy about putting in whatever parts take up the slop and leave room for an oil film. That's what the pro's call "select fit".
The driveshaft center bearing is gone? That would sure explain some of the noise. Another beach day may be in order.....
