5' Agri Bush Hog- 1st bush hog............Help!
   / 5' Agri Bush Hog- 1st bush hog............Help! #1
BuddyBOTA3130
St Paul, Arkansas
Kubota 3130 HST
5\' Agri Bush Hog- 1st bush hog............Help!
Looking for some pointers. (stupid) question #1:
1. How do you attach the drive shaft to the PTO shaft?
2. What's next?
3. Initial adjustments?
Don't have much to mow- side of 1/4 mile road, some trails, new garden patch.
Is AGRI pretty cheap stuff. I wasn't going for HD since I don't have much to do. Brush is small stuff.
Thanks fellas. Please be patient! /forums/images/graemlins/crazy.gif <font color="black"> </font>
   / 5' Agri Bush Hog- 1st bush hog............Help! #2
Re: 5\' Agri Bush Hog- 1st bush hog............Help!
<font color="blue"> 1. How do you attach the drive shaft to the PTO shaft?</font>
Get some multipurpose grease and smear it on the sliding part of the shaft and the pto splines. Assemble the two pieces of the shaft and then attach the spline end to the pto. Usually there is a ring that you pull or push to enable the shaft to slide onto the pto - when it's in place make sure it's locked to the pto shaft by pulling/pushing the shaft. You don't want it coming off during operation. You want to make sure your 3ph is adjusted to allow the cutter to move enough to follow the terrain without binding the pto shaft or the 3ph draft arms and top link. Your tractor manual should tell you how to do this. Also, you want to make sure you can turn without anything touching your rear tires.
<font color="blue"> 2. What's next? </font>
With the tractor and cutter on level ground make sure the cutter is adjusted to the height you want.
<font color="blue"> 3. Initial adjustments? </font>
Above.
HTH
   / 5' Agri Bush Hog- 1st bush hog............Help! #3
1. Your PTO shaft may have a collar type lock or it may have a spring loaded pin that you have to push in. If you can turn the tractor PTO shaft by hand, it is easy to align the splines. Just hold the PTO shaft against the tractor shaft and turn the tractor shaft until you feel it start to slip on. Then press the pin or pull the collar and slide the PTO on the tractor shaft. If you can't turn the tractor shaft, then you can turn the PTO drive shaft slowly until it slides on. A little harder to turn, but not too difficult.
2. Move to level ground. Look at the deck side to side. Is it level? If not, one of your lift arms should be adjustable so that you can shorten/lengthen it to get the deck level.
3. Decide how high you want to cut your grass. Raise the front of the deck to the height you want. Then look at the deck, front to back. Is it level? You want the front to be level or slightly lower than the back. You may have to adjust the rear wheel to do this.
4. Go mow. /forums/images/graemlins/grin.gif
Thanks for the help. Here goes.........
   / 5' Agri Bush Hog- 1st bush hog............Help! #5
</font><font color="blue" class="small">( Don't have much to mow- side of 1/4 mile road, some trails, new garden patch. )</font>
If there is a ditch on the side of the road please be very careful not to get too close to it. Wear your seatbelt and have your ROPS in the upright position.
   / 5' Agri Bush Hog- 1st bush hog............Help! #6
Since you're new to the tractor, I'm going to tell you the obvious. <font color="red"> MAKE SURE THE TRACTOR IS OFF AND THE KEY IS IN YOUR POCKET BEFORE YOU DO ANYTHING WITH THE PTO.</font> PTO's have killed and maimed thousands of people, BE CAREFUL.
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
Reading Classic I I (A57880)
Reading Classic I...
1996 International Water Truck with a Caterpillar Engine (A55315)
1996 International...
2021 Club Car Carryall 500 Electric Utility Cart (A55851)
2021 Club Car...
UNUSED PABREAK TCR380-84" HYD TILLER (A57193)
UNUSED PABREAK...
2016 CATERPILLAR CB34B SMOOTH DBL DRUM ROLLER (A52707)
2016 CATERPILLAR...
