Re: 5\' or bigger implements by Compact Tractors?
Are we lost in this discussion about density change with temperature change? Or, am I the only one not understanding you on this very simple issue? Yes, for air (actually, for ideal gas,) PV/T = constant = P1V1/T1 = P2V2/T2. But, in our case (rigid box), V1 = V2 = V = Volume of rigid box. Since mass M of air in this rigid, closed box is same, a constant M (constant) / V (constant) = Density = Constant and doesn't matter whether you increase/decrease P2 or T2. Constant volume process in a closed cycle can be considered as a rigid box process in which density doesn't change. Combustion (in gasolines) and heat rejection stages (in both of gasoline & diesel) are constant volume processes, that is, the density doesn't change even though temperature increases (during the combustion) or decreases (during the heat rejection after expansion of gas.) See attached P-V diagram of a tractor (4-1: compression, 1-2: combustion, 2-3: expansion, 3-4: heat rejection.) (In gasoline, 1-2 stage too is constant volume process.)
Concerning safety, probability of giving some damage to the tractor frame, body, etc when increasing HP by charging; I already gave 5' drum mower example. Another one; I have seen on a forum here someone is pulling a 60"-72" tillers with a compact tractor. Any problem occured? No. Then, why should a problem occur when pulling the same tillers, with a charged compact?
