50 hour service on a L3430
   / 50 hour service on a L3430 #21
it's in your manual. i believe it somehow involves pressing two buttons at the same time
   / 50 hour service on a L3430 #22
   / 50 hour service on a L3430 #23
My 2 cents after the service...
The oil and filter change were easy, got that out of the way first.
Getting the other 2 filters off took a bit of muscle.
The drain plugs were easy to get to and worked as expected. The drain plug that's recessed needs a hex head wrench - why? I had to go buy a set just to get the one I needed.
Took everyones advise and used a drill pump for the SUDT fluid. It was difficult to get it primed, but easier than holding buckets over a funnel for a half hour.
I jacked up the rear end of the tractor to fit a 5 gallon bucket under it for draining. That worked nicely but I still only got 10 gallons drained out with all 4 plugs removed. Some still spilled on the wood floor of my shed, that floor won't be rotting anytime soon.
Changed primary air filter, the secondary looked like new so I re-used it.
Over all, it wasn't that bad but I'm glad the SUDT fluid won't need to be done for another 200 hours. When I finshed, the tractor got a wash & wax, looks and feels like new!
   / 50 hour service on a L3430 #24
   / 50 hour service on a L3430 #25
(I still only got 10 gallons drained out with all 4 plugs removed.)
I just completed my 50 hour service and I also only got about 10 gallons out with all 4 drain plugs removed, I guess Kubota's figures are base upon a dry unit because there is probably more SUDT still in the system that is unable to drain.
The drain pan I ordered was delivered and IMO was worth every penny. I didn't spill any substantial amount of fluid on the floor, although there was a few little splash drops from when the fluid first hit the pan.
The pan has a three inch drain hole with four smaller holes down inside, I assume to prevent dropping the tractor's drain plug(s) down into the pan. The pan comes with a screw in plug for the drain hole and four places to prop up filters to drain, there is a small removable screw-in plug in the corner to act as a vent, and on the end there is a drain spout with a screw on cap to empty the pan. Furthermore, the pan has a plastic wheel shaft on one end to help move the pan around while you are on the ground. Once I installed the SUDT into the tractor, disposal of the old fluid was fairly easy. I set the drain pan up on top of four 5 gallon buckets, with some wood blocks to elevate the pan, and drained the old SUDT back into the new SUDT buckets. I highly recommend the pan as it makes this job a lot less tedious.
Jim
   / 50 hour service on a L3430 #26
Jim
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
2011 HAULMARK ENCLOSED CARGO SINGLE AXLE TRAILER (A56129)
2011 HAULMARK...
Hose Reel (A53424)
Hose Reel (A53424)
Ex Mark Zero Turn Mower (A54865)
Ex Mark Zero Turn...
2014 Nissan NV200 Cargo Van (A53422)
2014 Nissan NV200...
