Just finished my 50 hr service on my
B7500 and I thought I'd post the most useful tips I have gleaned from others and on my own.
1. The plastic sheet under the tractor is a great idea.
2. Removing the 4 drain plugs starting with the front tranny, then the mid PTO, and finally the rear axle plugs is the best method because it avoids high head pressure from the 2 drains below the rear axles. I worked with three different oil pans under the plugs, rotating them and emptying them as necessary.
3. Take a lunch break while the front tranny drains. /forums/images/graemlins/smile.gif I drained all 3.3 gallons.
4. The largest hydraulic filter goes on the right side of the tractor in front of the strainer. The smaller (blue) filter goes on the left side.
5. After cutting the paint around the strainer nut with a razor blade, I found that my Craftsman 15 inch adjustable wrench worked really well to remove the strainer. Just be sure to snug it up real well on the nut. I found a few particles on the strainer, but not many. I wonder what the "non-flammable solvent" is that my manual suggests to use. Offhand the only non-flammable solvent I can think of is water! The air pressure idea sounds reasonable. I just flicked off the particles with a piece of paper towel, probably not the best method.
6. Be sure when checking wheel nuts to tighten the nut on the inside of each rear wheel. Mine were loose: no where near 100 ft-lb.
7. Don't forget to adjust the clutch nut. My clutch had too much play. Easy job.
8. All in all, this job is only slightly more complex than changing engine oil, so there's no real reason for someone like me to have the dealer do the service.
Now I think I'll print this so I don't forget it for next time!
